System Restore does not work and returns the following error 0x80070005:__
2009-11-30T18:24:22+00:00
"System Restore did not complete successfully, Your computer's files and settings were not changed.
Details;
System Restore could not access a file. This is probably because an anti-virus program is running on the computer . Temporally disable your antivirus program and retry System Restore.
An unspecified error occurred during System Restore, (0x80070005)"
I have turned off my Zone Alarm Extreme Security software, but I get exactly the same answer.
Unfortunately the message does not tell me which file(s) are causing the problem and the error message is so vague I can't try to resolve the issue.
2009-12-01T16:43:33+00:00
Hi Rotherboy,
Thanks for posting in Microsoft answers!
Firstly, I’d suggest you to uninstall the antivirus program and try to perform a system restore and check if that fixes the issue.
Refer the link below for more on uninstalling programs:
Uninstall or change a programhttp://windows.microsoft.com/en-us/windows7/Uninstall-or-change-a-program
If the above steps do not help, try doing a system restore from safe mode and check if that works fine.
Refer the below link for more details on starting your computer in safe mode:
Start your computer in safe modehttp://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Let us know if this helps!
Regards,
Gokul - Microsoft Support
65 additional answers
    2013-04-12T14:05:54+00:00
    ...and why my next computer will be an Apple product
    2012-05-30T13:28:47+00:00
    I am having the same issue with BitDefender Internet Security 2012.  HAve not been able to restore after installing? Any help would be appreciated. Regards, KH
    2011-12-18T22:42:09+00:00
    It was perfectly creating restore points and restroring to those points previously while all those untivirus and zonealarm staff loaded. (avira + zonealarm +windows defender).
    But after the format and  reinstalling the system image back to solid state drive from the orijinal image back-up (SeagateDiskwizard), this message of Access is denied has stuck with system restore point create and restore.
    2011-12-08T22:26:32+00:00
    I'm having same problem but I have Kaperski.....must be someing with MS
