System Restore does not work and returns the following error 0x80070005:__
2009-11-30T18:24:22+00:00
"System Restore did not complete successfully, Your computer's files and settings were not changed.
Details;
System Restore could not access a file. This is probably because an anti-virus program is running on the computer . Temporally disable your antivirus program and retry System Restore.
An unspecified error occurred during System Restore, (0x80070005)"
I have turned off my Zone Alarm Extreme Security software, but I get exactly the same answer.
Unfortunately the message does not tell me which file(s) are causing the problem and the error message is so vague I can't try to resolve the issue.
2009-12-01T16:43:33+00:00
Hi Rotherboy,
Thanks for posting in Microsoft answers!
Firstly, I’d suggest you to uninstall the antivirus program and try to perform a system restore and check if that fixes the issue.
Refer the link below for more on uninstalling programs:
Uninstall or change a programhttp://windows.microsoft.com/en-us/windows7/Uninstall-or-change-a-program
If the above steps do not help, try doing a system restore from safe mode and check if that works fine.
Refer the below link for more details on starting your computer in safe mode:
Start your computer in safe modehttp://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Let us know if this helps!
Regards,
Gokul - Microsoft Support
65 additional answers
    2018-02-03T02:51:07+00:00
    I've had the same issue - first noticed it in 2016 and it has not worked since, no matter what I do.  No anti-virus/malware programs installed.  I turned Windows Defender off & tried in safe mode and got the same error.  The last time I fooled around with this in November 2017 I did the exact same steps but kept getting a different error.  See the two attachments.
    2018-01-26T20:13:29+00:00
    How can you delete  the antivirus if you can't get into your settings when your windows won't work
    2018-01-07T08:29:11+00:00
    .....I totally agree
    2018-01-07T02:51:40+00:00
    I get this message ''An unspecified error occurred during System Restore, (0x80070005)''
    when I try system restore..I don't have any anti virus software except win defender.
    and I still get this message...and no system restore.
