System Restore does not work and returns the following error 0x80070005:__
2009-11-30T18:24:22+00:00
"System Restore did not complete successfully, Your computer's files and settings were not changed.
Details;
System Restore could not access a file. This is probably because an anti-virus program is running on the computer . Temporally disable your antivirus program and retry System Restore.
An unspecified error occurred during System Restore, (0x80070005)"
I have turned off my Zone Alarm Extreme Security software, but I get exactly the same answer.
Unfortunately the message does not tell me which file(s) are causing the problem and the error message is so vague I can't try to resolve the issue.
2009-12-01T16:43:33+00:00
Hi Rotherboy,
Thanks for posting in Microsoft answers!
Firstly, I’d suggest you to uninstall the antivirus program and try to perform a system restore and check if that fixes the issue.
Refer the link below for more on uninstalling programs:
Uninstall or change a programhttp://windows.microsoft.com/en-us/windows7/Uninstall-or-change-a-program
If the above steps do not help, try doing a system restore from safe mode and check if that works fine.
Refer the below link for more details on starting your computer in safe mode:
Start your computer in safe modehttp://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Let us know if this helps!
Regards,
Gokul - Microsoft Support
65 additional answers
    2015-02-19T23:27:35+00:00
    same here - barebone 8.1 nothing but basics installed....MS AV...
    MS Sucks, i would run ubuntu if this wasnt a corp machine...
    2015-02-16T09:40:22+00:00
    hii.. i am having this problem too... i have tried to uninstall the AVG but when i' m unable to indicating that ' wait until the current program is uninstalling or unchanging' when there is nothing as such.
    2015-02-11T11:56:11+00:00
    I tried shutting down .. AVG .. and Security essentials .. ( I run BOTH )
    NO SUCCESS  .. same message
    SAFE MODE !   nothing shut down  Both antivirus running ..
    W ORKED SLICK AS SNOT!  1st try !
    TOOOOOOooooo  EASY!  ..
    I knew that ..why the hell did I not think of it .. Check the fuel gauge prior to removing the transmission !
    SUGGESTION :   "HOW could we improve it "  '???
    Simple addition ..  System has not completed due to ' 123 Wah-zoo '
    Blocking the restore point .. Close or shut down this program
                                                and THEN redo system retore
    2015-01-25T21:27:19+00:00
    I just ran into this problem on Win 7 Pro 64-bit SP1.  I am using Avast Free 2015 with its Enable Hardware-Assisted Virtualization turned OFF.
    Going into Safe Mode and then doing the System Restore worked.
    As this problem has continued for a long time, and as System Restore is a very important feature in a crisis, MS's failure to fix this after so many years is despicable.  An insult to its pay-through-the-nose customers.
