I'm not even using a commercial anti-virus program. I use Microsoft's Security Essentials. I turn it off (that is, I shut off the "real-time protection" in that program), but I still cannot complete System Restore and I once again the dreaded 0x80070005
message.
On my old machine, a Dell Dimension running Windows XP, I was able to readily do a System Restore in minutes to remove spyware or pop-ups or even an actual virus program: by disconnecting from the internet and then returning my computer to the same shape
it was in a couple days earlier, before any symptoms of the bug had developed. I never even needed a commercial anti-virus program, in five years. The Microsoft protection, updated regularly, was always enough--helped out now and again with a System Restore
that dumped whatever bug I had picked up on the net.
So now, with a brand new HP running Windows 7, I can never complete a System Restore and I always get the dreaded 0x80070005 message. There is also a suggestion, in the error message, that my anti-viral program might be blocking the System Restore process. So
I've shut down the real-time protection of my Microsoft Security Essentials program, and still no luck with System Restore. Same dreaded error message.
(And I don't want System RECOVERY, which is for a failing computer in need of serious software repair. I want System RESTORE. If it's not working from the System Tools menu in the Start-Up menu list, why would getting to it by way of major surgery make it
work any more successfully? I know you can supposedly get to System Restore by going into System Recovery Options menu, but I don't want to uninstall all my programs and virtually reformat the hard drive by reinstalling the operating system. I don't have a
problem with the operating system. I just have a computer that's very slow to load internet pages. And yes, I'm dumping my cache probably three times a week.)
Those System Recovery Options are too drastic for me: it says I can lose files and all the programs I've installed since I got my machine. I wouldn't touch them. I sure do miss my old System Restore capability. It was like blowing out some water-contaminated
gasoline and filling up with high octane. Back up to full speed in minutes. Kept me happy for years
