Hi there. I've actually got the problem fixed - that is if you have a RealTek sound card. You need to contact them about the problem and they should give you a diagnostic tool. Run the tool and get the info. Then send it back to RealTek. I had such good customer service from them it was all done within Half an hour!! They sent me an updated version of their driver that was in the beta stage but had the modification Turn Off Pull Mode (if that makes any sense) and it works completely fine!! I've even got new features with it too - special enhancments that can change the pitch of the audio, Karaoke mode, Environment effects and Equaliser. No crackling or distorted sound whatsoever.
Distorted crackling sound when using either 32/64 bit of Windows 7 on Fujitsu Siemens Esprimo V5535 using High Definition Audio Device.
Hi there. I have a problem with sound on my computer. I believe its possibly a bug in Windows 7. Every time I try to play music or watch a video there is some distorted crackling sounds that also come with the audio. I didn't have this problem in XP or Vista. I have tried everything to resolve this problem from reinstalling the sound drivers to changing them to different ones and actually trying different versions of Windows 7 but to no avail. I had no problems with it using the Windows 7 Beta but I do now running the 7600 version. And my lapyop is well capable of running Windows 7 - 2.26Ghz CPU, 2GB Ram, 320MB Graphics card - its very fast. Only problem is sound. I have even tried the Realtek sound drivers for it and I get the same problem - and they are the most recent up-to-date ones.
Please help!!!
Ok everyone. Here is the link they sent me to get the driver files that work. This should sort it all out.
ftp://ftp3.realtek.com.tw/5898_PG281_Win7_TurnOff_PullMode_Upd.zip
The username is enduser and the password is enduser256
Remember - this only works for Realtek AC'97 and Realtek High Definition Audio Sound Cards.
56 additional answers
2011-11-27T04:51:49+00:00 Hi, many thanks, I have the same Atheros AR8131 PCI-E Gigabit Ethernet Controller on my VAIO VPCS13XE. All I needed to do to stop the problem was to disable the Atheros Controller, confirm that the distortion had gone and then enable it. The problem has stayed away so far but I do have a fix.
Thanks again.
2011-11-02T12:23:11+00:00 Hello,
the file is no longer in the ftp, where can i get this driver ?
Thank you.
2011-10-25T19:51:59+00:00 problem fixt
Control panel, then Properties of Speakers then "Advanced" tab. Here is a drop-down menu where you can change "bit depth". By default it set to 16-bit (CD Quality) and all I had to do was to change it to 24-bit (Studio Quality) :)
