Distorted crackling sound when using either 32/64 bit of Windows 7 on Fujitsu Siemens Esprimo V5535 using High Definition Audio Device.
2010-01-18T08:02:56+00:00
Hi there. I have a problem with sound on my computer. I believe its possibly a bug in Windows 7. Every time I try to play music or watch a video there is some distorted crackling sounds that also come with the audio. I didn't have this problem in XP or Vista. I have tried everything to resolve this problem from reinstalling the sound drivers to changing them to different ones and actually trying different versions of Windows 7 but to no avail. I had no problems with it using the Windows 7 Beta but I do now running the 7600 version. And my lapyop is well capable of running Windows 7 - 2.26Ghz CPU, 2GB Ram, 320MB Graphics card - its very fast. Only problem is sound. I have even tried the Realtek sound drivers for it and I get the same problem - and they are the most recent up-to-date ones.
Please help!!!
2010-09-22T11:13:43+00:00
Hi there. I've actually got the problem fixed - that is if you have a RealTek sound card. You need to contact them about the problem and they should give you a diagnostic tool. Run the tool and get the info. Then send it back to RealTek. I had such good customer service from them it was all done within Half an hour!! They sent me an updated version of their driver that was in the beta stage but had the modification Turn Off Pull Mode (if that makes any sense) and it works completely fine!! I've even got new features with it too  - special enhancments that can change the pitch of the audio, Karaoke mode, Environment effects and Equaliser. No crackling or distorted sound whatsoever.
2010-09-24T15:14:36+00:00
Ok everyone. Here is the link they sent me to get the driver files that work. This should sort it all out.
ftp://ftp3.realtek.com.tw/5898_PG281_Win7_TurnOff_PullMode_Upd.zip
The username is enduser and the password is enduser256
Remember - this only works for Realtek AC'97 and Realtek High Definition Audio Sound Cards.
56 additional answers
    2014-12-14T12:07:36+00:00
    I had same problems with Fujitsu Esprimo V5535 , speakers crackling randomly with windows 7.
    I went to Fujitsu website support , downloaded the driver audio for windows vista
    http://support.ts.fujitsu.com
    1. Home >
    2. Support
    > Computing Products> Client Computing Devices> Notebooks > Drivers & Downloads
    choose model V5535 , esprimo
    driver is called **HD ALC 268 Sound codec** for windows vista , you save it on your PC.
    Then you can do device manager & update the audio driver with the file downloaded & it worked ok for me that way , no crackling any more.
    BR
    2014-09-15T17:51:23+00:00
    quintar1 at hot male dot com
    not too worried about my privacy! :)
