Unable to Rip Audio CD using teh Media player, Windows 7 Ultimate.__Error Pop up : Windows Media Player cannot rip one or more tracks from the CD.
2009-10-24T18:16:09+00:00
I am runing the Windows 7 Ultimate
And is unable to rip any audio muice CD into the library.
The pop up error:
2010-09-17T05:08:50+00:00
This worked for me:
Open Windows Explorer -> right click music under libraries -> choose properties -> choose a valid folder for storing music... (mine was a network location)
2009-10-25T17:35:45+00:00
Hi James Tam,
Welcome to Microsoft Answers Community Forums!
Method 1:-
You might be able to complete the rip by turning on error correction.
> In Windows Media Player ->Click on Tools -> Options -> Devices, click the CD burner, choose> Advanced, and set the error correction to On.
Method 2:-
There are two ways to change rip settings while in the Player Library. You can insert a CD into your CD drive and click Rip settings, or you can click the Rip Music tab in the Options dialog box. The Rip Music tab in the Options dialog box offers additional options that aren't available on the Rip settings menu.
To rip music from a CD, do the following:
1.      For best results, make sure that you are connected to the Internet before you begin.
When your computer is connected to the Internet, the Player attempts to retrieve media information about the tracks being ripped from an online database. The Player then adds the information to the files during ripping.
Note that you can rip a CD when your computer isn't connected to the Internet. However, the Player won't be able to identify the name of the CD, the artist who created it, or the names of the songs until you go online.
2.      Insert an audio CD into the CD drive.
3.      (Optional) If you want to select a different format (for example, MP3 instead of WMA) or bit rate (for example, 192 Kbps instead of 128 Kbps) for the files created during ripping, in the Player Library, click the Rip settings menu, and then click Format or Audio Quality.
4.      (Optional) If you don't want to rip every song, in the Player Library, clear the check boxes next to the songs you don't want to rip.
5.      Click the Rip CD button in Now Playing mode or Rip CD in the Player Library to begin ripping.
1.      For more information visit the following link:-
http://windows.microsoft.com/en-us/windows7/Change-settings-for-ripping-music
 Let me know if this helped.
Regards,
Divya R – Microsoft Support.
79 additional answers
    2011-12-29T15:16:46+00:00
    Hello, I have done all of your suggestions but I still recieve the error message can't rip one or more tracks.  Thanks Bikrdad
    2011-12-12T23:58:34+00:00
    I solved the dilemma of NOT being able to find or locate the RIP Music Tab on Windows Media player using Windows 7 OS. Very simple solution, you can still rip music by going to START >> All Programs >> Click on Windows Media Player. When Windows Media Player opens Simply click on  TOP left where it says ORGANIZE >> then click on the drop down menu where it says>> OPTIONS >>  Then click on TOP where it says RIP MUSIC then simply put a check mark in the box that says RIP CD AUTOMATICALLY >>  Put a check mark to Eject CD automatically when finished  >> Choose a location above that where you want the music to be saved >> also click to format it to MP3 >>> Click APPLY >>  Click OK   >>> Then when you are ready  to RIP music from a CD. simply Open up Windows Media Player and Insert  any CD with Music on it which you want to  rip, and just let Windows Media Player do the rest. Who really cares about the RIP TAB or the fact that you cant find the RIP tab anywhere. At least you will be able to RIP music off any CD you want. But then just make sure you go back and remove the check  mark where it says Automatically RIP CD.. otherwise, anytime you want to play a CD using Windows Media Player, it will RIP automatically, which I dont believe you want to do. I hope this helps. It worked for me and helped me work around all the other complicated options.
    Good luck,
    Chris
    e mail ******@yahoo.com
    2011-12-03T09:22:44+00:00
    Thank you very much Zpete, this worked for me
