This worked for me:
Open Windows Explorer -> right click music under libraries -> choose properties -> choose a valid folder for storing music... (mine was a network location)
I am runing the Windows 7 Ultimate
And is unable to rip any audio muice CD into the library.
The pop up error:
Windows Media Player cannot rip one or more tracks from the CD.
This worked for me:
Hi James Tam,
Welcome to Microsoft Answers Community Forums!
Method 1:-
You might be able to complete the rip by turning on error correction.
> In Windows Media Player ->Click on Tools -> Options -> Devices, click the CD burner, choose> Advanced, and set the error correction to On.
Method 2:-
There are two ways to change rip settings while in the Player Library. You can insert a CD into your CD drive and click Rip settings, or you can click the Rip Music tab in the Options dialog box. The Rip Music tab in the Options dialog box offers additional options that aren't available on the Rip settings menu.
To rip music from a CD, do the following:
1. For best results, make sure that you are connected to the Internet before you begin.
When your computer is connected to the Internet, the Player attempts to retrieve media information about the tracks being ripped from an online database. The Player then adds the information to the files during ripping.
Note that you can rip a CD when your computer isn't connected to the Internet. However, the Player won't be able to identify the name of the CD, the artist who created it, or the names of the songs until you go online.
2. Insert an audio CD into the CD drive.
3. (Optional) If you want to select a different format (for example, MP3 instead of WMA) or bit rate (for example, 192 Kbps instead of 128 Kbps) for the files created during ripping, in the Player Library, click the Rip settings menu, and then click Format or Audio Quality.
4. (Optional) If you don't want to rip every song, in the Player Library, clear the check boxes next to the songs you don't want to rip.
5. Click the Rip CD button in Now Playing mode or Rip CD in the Player Library to begin ripping.
1. For more information visit the following link:-
http://windows.microsoft.com/en-us/windows7/Change-settings-for-ripping-music
Let me know if this helped.
Regards,
Divya R – Microsoft Support.
God bless....I've tried "everything" - and this was the solution. Now I will always change folder to a valid one after ripping to my android, for example. There must be a bud in wma - why does it get so stupid when we use movable storage units..Thank you!
I used this method and it worked right away. Thanks for the advice.
BW
Thanks very much Zpete, have been to lots of so called fixes with no luck.I am very happy to say yours worked.Thanks very much again you are a star
