How to change monitor 1 for monitor 2
2010-05-05T20:48:00+00:00
I have a Gateway with HDMI and Vga outputs. I connect the VGA to a regular computer monitor, and the HDMI to a new 37 HDTV, but by default the HDMI output is identified as Monitor 1 and the vga to monitor 2, I new to change the identity of the monitors so 1 to be 2 and 2 to be 1, please advice
2010-05-05T22:36:14+00:00
Right Click Desktop - Graphics Properties
Right Click Desktop - Graphics Options
Right Click Desktop - Personalize - Display Settings
These should help you set them up.
How to Setup Dual Monitors in Windows 7
http://www.online-tech-tips.com/windows-7/how-to-setup-dual-monitors-in-windows-7/
Two monitors are better than one
http://www.microsoft.com/athome/organization/twomonitors.aspx
Work and play better with multiple monitors
http://windows.microsoft.com/en-us/windows7/work-and-play-better-with-multiple-monitors
Move windows between multiple monitors
http://windows.microsoft.com/en-US/windows7/Move-windows-between-multiple-monitors
Multiple monitors : frequently asked questions.
http://windows.microsoft.com/en-AU/windows-vista/Multiple-monitors-frequently-asked-questions
Hope this helps.
Rob Brown - Microsoft MVP - Windows Desktop Experience : Bicycle - Mark Twain said it right.
51 additional answers
    2014-10-26T00:20:50+00:00
    I found a better and easier solution to switch to your monitor identity basically switching 1 and 2.
    1. Turn off computer fully.
    2. Disconnect all DVI or monitor display. (In my case i have Benq (DVI) and Samsung (HDMI).
    3. Turn on computer and wait until its in the Log in screen. (You won't actually see it since all monitor is disconnected. Just guess or wait till you hear the log in sound).
    4. Connect the monitor that you want to be Display 1st. (Extra: Log in and open up display settings where you see display 1 and 2 for visualization purposes.)
    5. Then connect the monitor that you want to be Display 2nd.
    6. And so on. Voila!! hope this helps.
    2014-10-02T20:33:21+00:00
    Not sure how this copy'/paste "non-answer" got marked as an Answer... Probably just to add to the MVP points? The actual question was how to change display identity.
    2013-03-12T14:46:55+00:00
    Thank you so much!
    2011-07-18T06:36:00+00:00
    Hi Wumbo,
    Please start your own thread and include the System Maker (Motherboard Maker for
    custom systems) and the Video card/device maker. Help us to help you.
    On many you can Right Click the Desktop - Graphics Properties - and assign either
    device as Monitor 1 (Primary device) or Monitor 2 (Secondary device).
    Check with the System Maker and the video card/device maker's support and forums.
    Hope this helps.
    Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle - Mark Twain said it right.
