How to remove the edge sidebar from Edge workspace?
2023-08-27T13:51:46+00:00
Hi.
I am using the latest stable version of Microsoft Edge (Version 116.0.1938.62 (Official build) (64-bit)).
I want to hide/remove the edge sidebar. It doesn't work in Edge Workspace.
I have been facing the error for the last 1 month. I have only encountered the problem in the workspace. When Microsoft Edge launched the Edge Workspace feature, this option worked well. But now, I can't remove or hide the sidebar in the workspace.
Microsoft Edge | Other | Windows 10
2024-01-08T18:35:34+00:00
try edge://flags/#edge-workspaces-skype-entry-point and choose one of the options "Enabled" or "Enabled Hub chat icon" this adds one icon to the browser toolbar but removes the sidebar. It works for me on Stable and Dev versions
After this issue happening again, this fixed it for me. "Enabled Hub chat icon" is a bit less intrusive.
The old solution in which you needed to delete the workspace etc doesn't work anymore.
46 additional answers
    2023-10-12T11:29:12+00:00
    not working for the existing workspace in macos Version 119.0.2151.2 (Official build) Dev(arm64). Either the issue has not reached the dev team or it seems they are not concerned about such small issues.
    2023-10-12T11:22:09+00:00
    The new update on macos Version 119.0.2151.2 (Official build) Dev(arm64) has again messed up things. The beauty is back again. This scenario compels me not to update edge.
    2023-10-08T05:21:31+00:00
    I'm having the same issue for a very long time. Why they still haven't fixed this bug yet? Disabling edge://flags/#edge-workspaces-skype doesn't fix this issue.
    2023-09-26T23:05:05+00:00
    Still not fixed for macos
    Version 119.0.2116.0 (Official build) Dev(arm64)
