Other issues or features related to Microsoft Edge on Windows 10
Hi.
I am using the latest stable version of Microsoft Edge (Version 116.0.1938.62 (Official build) (64-bit)).
I want to hide/remove the edge sidebar. It doesn't work in Edge Workspace.
I have been facing the error for the last 1 month. I have only encountered the problem in the workspace. When Microsoft Edge launched the Edge Workspace feature, this option worked well. But now, I can't remove or hide the sidebar in the workspace.
try edge://flags/#edge-workspaces-skype-entry-point and choose one of the options "Enabled" or "Enabled Hub chat icon" this adds one icon to the browser toolbar but removes the sidebar. It works for me on Stable and Dev versions
After this issue happening again, this fixed it for me. "Enabled Hub chat icon" is a bit less intrusive.
The old solution in which you needed to delete the workspace etc doesn't work anymore.
I just use the regular Edge browser, the steps I took are as follows:
That's it. The vertical sidebar is off. Restart Edge and you are good to go.
Ed
Please try relaunching your browser, then try turning off the Show Sidebar option again.
If the issue persists, I recommend submitting a report using the feedback option by pressing Alt + Shift + I on your keyboard or by clicking the 3-dot menu > Help and Feedback > Send feedback. With this, the Edge dev team will be notified about your concern and hopefully address the issue in their next update.
Please let me know if you need any further assistance. I will be glad to help.
Hi, I am Van. I'll be glad to assist you today.
Please try the workaround below to hide the sidebar.
