How to remove the edge sidebar from Edge workspace?
2023-08-27T13:51:46+00:00
Hi.
I am using the latest stable version of Microsoft Edge (Version 116.0.1938.62 (Official build) (64-bit)).
I want to hide/remove the edge sidebar. It doesn't work in Edge Workspace.
I have been facing the error for the last 1 month. I have only encountered the problem in the workspace. When Microsoft Edge launched the Edge Workspace feature, this option worked well. But now, I can't remove or hide the sidebar in the workspace.
Microsoft Edge | Other | Windows 10
2024-01-08T18:35:34+00:00
try edge://flags/#edge-workspaces-skype-entry-point and choose one of the options "Enabled" or "Enabled Hub chat icon" this adds one icon to the browser toolbar but removes the sidebar. It works for me on Stable and Dev versions
After this issue happening again, this fixed it for me. "Enabled Hub chat icon" is a bit less intrusive.
The old solution in which you needed to delete the workspace etc doesn't work anymore.
46 additional answers
    2023-12-04T06:54:09+00:00
    After messing with settings, uninstalling Skype, denying all permissions for skype.com I ventured into searching for other Skype-related Edge settings and found this other one (Entry point for skype in workspace) and just like magic as soon as you turn it on (it's Disabled by default), it fixes the issue for my existing workspace without the need to delete and create a new one!
    This worked for me thanks!
    2023-12-01T01:21:41+00:00
    This worked for you in an Edge Workspace window or just a regular Edge window? Cos the thread is about removing it on Edge Workspace windows.
