Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-20T16:23:11+00:00
    Same issue. I went to delete the app, and it came up with a repair option. After the repair, I am able to close the app when I want.
    2025-05-20T15:59:01+00:00
    it's clearly Microsoft's way of forcing users to use Edge - don't allow it to be closed!!
    2025-05-20T15:53:25+00:00
    We live in a lawless society. What is Microsoft doing that disabled the close program x?
    2025-05-20T15:41:22+00:00
    This worked for me too. I tried the DISM and SFC solution above first. It had no effect.
    2025-05-20T15:19:56+00:00
    For me, I had to disable each, have it restart then re-enable them. That is when it started working for me.
