Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-20T15:15:23+00:00
    I was having the same problem with Windows 11!
    I did find a solution. I removed the Ad-Blocker and all was well.
    2025-05-20T14:52:11+00:00
    Hi Thank you for the reply. I just cleared the history and browsing data and it worked again. Regards Mark
    2025-05-20T13:46:01+00:00
    Turning off "Use Graphics Acceleration" solved the issue for me. Thanks!!
    2025-05-20T13:43:48+00:00
    Thanks Larry. This worked for me!
    2025-05-20T13:18:21+00:00
    Thanks Larry. This worked for me.
