Other issues or features related to Microsoft Edge on Windows 10
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
It was "Use graphics acceleration when available" for me. All of the other settings were already off and I was able to close Edge after turning off the graphics acceleration setting. Thanks!
I had the same issue where Edge would not close. The above fix of turning off the settings worked for me, Thanks!!!
Same problem here! won't close
thank you sir that worked it was getting annoyying everytime i open a file it would not close
Thank you. Better solution than anything Microsoft offered.
