Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-20T19:41:42+00:00
    Thank you for the info. Worked like a charm.
    2025-05-20T18:37:37+00:00
    This one worked for me, thanks!
    2025-05-20T17:37:12+00:00
    Thanks Larry, worked for me. Clearly a Microsoft issue that's been there without a fix for over a week now.
    2025-05-20T17:33:06+00:00
    Thanks Larry- that's worked for me too.
    How did this get past Microsoft's QA? Seems like a pretty big bug ...
    2025-05-20T16:57:07+00:00
    For me I only had to disable the Startup Boost and now it closes normally.
