Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-19T19:56:21+00:00
    Only the start up boost needed to be turned off for me.
    2025-05-19T19:43:54+00:00
    At the bottom of the browser settings list select More Tools then "Close Microsoft Edge". Then try to close normally from the tabs. If that alone doesn't work to restore normal closing, reset Edge first then from settings "Close Microsoft Edge". Just resetting Edge alone didn't work for me.
    2025-05-19T19:39:11+00:00
    worked great thanks
  4. Deleted
    2025-05-19T18:38:49+00:00
    This worked for me too. It was driving me crazy. Thank you.
