Other issues or features related to Microsoft Edge on Windows 10
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Thank you Larry!!!
This issue started after the most recent Windows update. I am on Win11pro
I'm on Windows 11 and it worked. Thanks!
I ran the commands, and nothing happened. The only way I can close the window is to go to the task manager. This started after I installed the required updates from Microsoft. I believe the updates are the issue.
I turned off the options that LarryRich1 listed above, use Task Manager to force close Edge. Then when I reopened it, I clicked on "Load Default pages" and then the X closed the window normally.
