Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-19T18:34:03+00:00
    I had the same issue, I saw the original post this morning and ran some tests before posting. This seems to be working for me:
    1 Click three dots at top right
    2 Click settings
    3 Click System and performance
    4 Click System
    Turn off the following:
    I have not determined which is the issue but turning each back on one at a time and testing can be done by you. But this did work for me.
    Larry
    IT Professional
    Turning off the graphics acceleration seems to have fixed it.
    2025-05-19T18:28:17+00:00
    Thank you Larry for the hint. For me, disabling "Enhance videos in Microsoft Edge" did it. It prompts you to restart Edge, which I confirmed.
    The nasty behaviour is gone - the browser can be closed as it should be.
    I could re-enable the option afterwards without experiencing the problem again.
    Mike
    2025-05-19T18:03:39+00:00
    Brilliant that works
    2025-05-19T17:59:26+00:00
    Worked right away.
    My motor habit is to press Ctrl-W to close Edge after having opened, say, a news article from News toolbar in the systray but, starting today, that stopped closing Edge. Had to use Task Manager.
    Thank you!
    2025-05-19T17:43:58+00:00
    2 Click settings
    4 Click System
    Larry
    IT Professional
    I did try changing these settings in Edge, restarted Edge and still the same problem but only on certain websites. I'm currently on a remote with a client trying to solve this problem. It seems when I open https://jigsawaday.com/ (which my client has used for years and I have even contacted the admin before) then I'm unable to close. I can still close down tabs except the last one.
    Any thoughts?
    Rick Stanton
    That PC Dude
