Other issues or features related to Microsoft Edge on Windows 10
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
For me, the User Graphics Acceleration was the only option on - turned off - worked. Thank you!
@Ephergie or anyone else experiencing this: Would you mind visiting edge://gpu/, clicking the button at the top of the page, and sharing the resulting text file?
Yes - this worked for me
"After turning off "Use graphics acceleration" and restarting edge - I could finally close Edge once more."
I'm having the same problem - it's really frustrating
