Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-19T17:02:39+00:00
    I've just been on MS live support for this issue.
    Try logging out of your Edge Profile, then log back in again.
    Worked for me
    2025-05-19T16:47:17+00:00
    Thanks Larry!
  3. Deleted
    2025-05-19T16:28:08+00:00
    This is the way.
    Thanks Larry!
    I was having the same problem and this 100% fixed it.
  5. Deleted
