Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-19T13:37:54+00:00
    Thanks Larry! Solved my issue too.
    2025-05-19T13:31:50+00:00
    Thank you. Your solution worked for me.
    2025-05-19T10:59:21+00:00
    I tried the above. The only one that was turned on was "Use graphics acceleration when available. I turned it off, restarted the browser and it now is working as before.
    2025-05-18T23:16:26+00:00
    me too
    2025-05-18T22:43:36+00:00
    Thank you Larry, the graphics acceleration was the culprit in my case.
    OS: Windows 11 Home
    CPU: AMD Ryzen 9 3950
    GPU: AMD Radeon 6700XT
    I had the same issue, I saw the original post this morning and ran some tests before posting. This seems to be working for me:
    1 Click three dots at top right
    2 Click settings
    3 Click System and performance
    4 Click System
    Turn off the following:
    I have not determined which is the issue but turning each back on one at a time and testing can be done by you. But this did work for me.
    Larry
    IT Professional
