Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-18T20:55:48+00:00
    Larry's suggestion worked for me. I find it pretty funny that MS screwed something up that can only be fixed by turning off settings they definitely want you to keep turned on.
    Oh well! 🤷
    I had the same issue, I saw the original post this morning and ran some tests before posting. This seems to be working for me:
    1 Click three dots at top right
    2 Click settings
    3 Click System and performance
    4 Click System
    Turn off the following:
    I have not determined which is the issue but turning each back on one at a time and testing can be done by you. But this did work for me.
    Larry
    IT Professional
    2025-05-18T20:45:03+00:00
    Same issue, using either Chrome or Edge. I try to click the close 'X' top right no response/action. it will not close. I have to use task manager to close edge/chrome.
    I will reboot and it will work again, but the same issue returns.
    Also windows keeps auto-dimming, if i don't move my mouse the screen will dim/dark. but will return to regular brightness if i move my mouse.
    too many issue with windows lately.
    2025-05-18T15:45:03+00:00
    Worked! 5-18-25 @11:44 AM
    2025-05-18T15:07:54+00:00
    This solution worked for me as well. (At least for now.) I toggled them all back on and it still shuts down normally. Thank you.
    2025-05-18T14:45:17+00:00
    Thank you I had tried everything. this worked. Appreciate you sharing this fix
    V/R
