hi when i open cmd as administrator and type the comand says access denied i cant use that
FIX: Insiders not able to switch channels - **UPDATED 8/3/2021**
Hello Windows Insiders!
Windows 11 is now in the Beta Channel, and some of you are wanting to move over from the Dev Channel. We've been getting some reports that some of you are not seeing the options to change in Settings > Windows Update > Windows Insider Program. We have a fix that should get you back on track. Please note, this fix is for devices that are not showing the Choose your Insider Settings and Windows Insider account settings, as in the image below.
If you are seeing this, please follow the steps below to restore the missing options:
- If you have Bitlocker enabled, please suspend it.
- Click Start
- In the search box, type cmd
- In the lower right of the search results, under Command Prompt, click Run as Administrator
- On the UAC prompt, click OK
- At the elevated command prompt, type: bcdedit /set flightsigning on
- Press Enter
- At the elevated command prompt, type: bcdedit /set {bootmgr} flightsigning on
- Press Enter
- Reboot the device
You should now see the missing options:
If performing these steps to not resolve your issue, please file a new feedback item in Feedback Hub, so we can investigate.
Thank you!
-The Windows Insider Team
Deleted
Deleted
2021-08-26T00:12:06+00:00 -
CrazyKats 19,420 Reputation points Volunteer Moderator2021-08-25T13:02:10+00:00 i did as you told but there is no change
Do you have the exact picture that's shown in
the original post?
If you do and the fix isn't working, then file
Feedback and share the link here for Eddie (MSFT).
2021-08-25T12:26:17+00:00 i did as you told but there is no change
