FIX: Insiders not able to switch channels - **UPDATED 8/3/2021**
2021-08-02T18:50:42+00:00
Hello Windows Insiders!
Windows 11 is now in the Beta Channel, and some of you are wanting to move over from the Dev Channel. We've been getting some reports that some of you are not seeing the options to change in Settings > Windows Update > Windows Insider Program. We have a fix that should get you back on track. Please note, this fix is for devices that are not showing the Choose your Insider Settings and Windows Insider account settings, as in the image below.
If you are seeing this, please follow the steps below to restore the missing options:
  1. If you have Bitlocker enabled, please suspend it.
  2. Click Start
  3. In the search box, type cmd
  4. In the lower right of the search results, under Command Prompt, click Run as Administrator
  5. On the UAC prompt, click OK
  6. At the elevated command prompt, type: bcdedit /set flightsigning on
  7. Press Enter
  8. At the elevated command prompt, type: bcdedit /set {bootmgr} flightsigning on
  9. Press Enter
  10. Reboot the device
You should now see the missing options:
If performing these steps to not resolve your issue, please file a new feedback item in Feedback Hub, so we can investigate.
Thank you!
-The Windows Insider Team
  1. Pauli O 16,380 Reputation points Volunteer Moderator
    2022-02-11T10:53:24+00:00
    That's all we know:
    Quote from Insider blog announcement:
    We will soon be giving Insiders a window in which they will be able to switch from the Dev Channel to the Beta Channel. Stay tuned for details in the coming weeks.
    What’s coming for the Windows Insider Program in 2022 | Windows Insider Blog
    2022-02-11T10:40:59+00:00
    Any idea when the next point in time will be where Dev and Beta have the same build? I don’t want to be in Dev but also definitely don’t want to install everything again.
  3. Deleted
  4. Johnny55 5,155 Reputation points Volunteer Moderator
    2022-01-31T14:24:12+00:00
    how can i get a clean install with my previous registration with microsoft.
    When you do the clean install, simply skip the part when it asks for a key. As long as you use same Pro or Home as previously activated, it will auto activate once online. Activation is tied into your HWID stored on MS servers. Have a great day.
    Regards,
