Surface Duo 2 Bluetooth Issues
2021-12-05T14:19:34+00:00
When connected to a Bluetooth audio device like my car or Surface Ear Buds I have the following problem:
Connects properly without issues. Listen to music or Audible for a few minutes and the audio stops. The audio doesn't pause, the Bluetooth doesn't disconnect but the sound just stops.
Disconnecting Bluetooth in audio device and surfaceduo2 and restarting helps but the problem will repeat. Makes BT unusable.
Anyone else have this problem??
Surface | Surface Duo | Sound and camera
    2022-03-04T16:52:16+00:00
    Had anyone switched to another messaging app away from Google Messages? I'm trying Signal at my default SMS... Haven't received any photos yet so not sure if they're going to be blurry there too...
    2022-03-03T16:20:36+00:00
    Thanks for the web app advice. I'm going to try that for now. I didn't realize that existed.
    -D
    2022-03-03T16:20:10+00:00
    I have the same blurry pics problem. I'm not sure why that happens.
    I'm going to try the web app for when I need to view those pictures. It's super annoying and cannot figure out why it works that way. It's a Verizon network thing I think...
    2022-03-01T21:45:40+00:00
    Do you have the exact behavior as OP? When this issue occurs does triggering a voice assistant command correct the audio issue like it did for me?
    Just trying to determine if we are actually having the same issue vs something similar.
    2022-03-01T21:43:21+00:00
    https://www.vzmessages.com/introduction/index.html
    Try web app on that page...
    I have it on my iPhone that's wifi only so I use that bit I think web app should work for you.
    Is worth a shot to switch back to Google messages then uninstall message+ to test if it's a fix for you.
