Good to hear Dan, glad my findings helped someone else it was very annoying.
-Derek
When connected to a Bluetooth audio device like my car or Surface Ear Buds I have the following problem:
Connects properly without issues. Listen to music or Audible for a few minutes and the audio stops. The audio doesn't pause, the Bluetooth doesn't disconnect but the sound just stops.
Disconnecting Bluetooth in audio device and surfaceduo2 and restarting helps but the problem will repeat. Makes BT unusable.
Anyone else have this problem??
-Derek
I don't use Verizon message+ plus but I do use Google messages and I am still having issues
Hmmm... removing the Messages+ app huh? Interesting. I'll have to try that, but that app was what I used to save photos from SMS messages. The Google Message app photos are crazy blurry. I tried Facebook Messenger and it doesn't allow me to save photos from SMS messages. What are you using for SMS messages that allows you to save photos and backup SMS messages and such? Messages+ stores items in a different way where no out of box SMS backup util can get to those messages.
Curious if you have the Verizon Messages+ app installed? Uninstalling it has completely resolved my Bluetooth issues.
I had problems with auto Bluetooth connections. Unpairing, the re-pairing seems to have helped.
