Surface Duo 2 Bluetooth Issues
2021-12-05T14:19:34+00:00
When connected to a Bluetooth audio device like my car or Surface Ear Buds I have the following problem:
Connects properly without issues. Listen to music or Audible for a few minutes and the audio stops. The audio doesn't pause, the Bluetooth doesn't disconnect but the sound just stops.
Disconnecting Bluetooth in audio device and surfaceduo2 and restarting helps but the problem will repeat. Makes BT unusable.
Anyone else have this problem??
Surface | Surface Duo | Sound and camera
    2022-02-09T21:33:57+00:00
    Same issue here. :-( Uhg!
    2022-02-08T12:57:32+00:00
    I have the same build number as you...
    2022-02-08T07:35:43+00:00
    The number I gave you is the build. Number which identifies the last update applied it is under settings then about that is what Microsoft asked me for when I called about the Bluetooth
    2022-02-08T02:15:18+00:00
    Curious what hardware version folks have?
    2022-02-07T22:48:46+00:00
    Interesting. I don't have AA in my truck so this is just BT connection to Ford MSFT SYNC.
