2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2016-06-18T07:51:03+00:00
    This is what the CPU graph looks like when a surface Pro is afflicted with this problem.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=0dad2792-fb33-4160-98a8-8c8540741e5b)
    2016-06-18T07:44:28+00:00
    This is totally unrelated to the original question, and completely unhelpful in the context of this subject.
    There is a serious flaw in the Surface Pro with Windows 10 that makes it no better than a regular desktop computer because you can never stray far from a power outlet. Not only does the battery run down quickly when the machine is idle, but the noisy fan runs continuously, and the lifetime of the CPU and the fan bearings are both going to be significantly impacted.
    There is clearly a background process running that consumes one entire CPU core all of the time. This is clearly a huge problem that Microsoft should be taking vert seriously, suggesting that we create a power plan is frankly insulting.
