2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2016-06-02T05:38:57+00:00
    Facing exactly the same problem here.
    It has been months and Microsoft is not doing anything. Brilliant.
    2016-04-12T05:41:20+00:00
    I have exactly the same issue!
    SP3 i7 512GB - and microsoft dock!
