2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2016-02-05T14:01:45+00:00
    I tried all of the fixes in this thread and nothing worked.  What I did find is that it is definitely my docking station causing the problem on start up.   If I undock, startup, then close the wings on the docking station when the sign in screen appears everything works just fine....it runs cool with system interrupts and compressed memory running at 0.1% each.  I have do the same thing if I am waking from hibernation or sleep as well.
    2015-11-08T04:35:44+00:00
    I found a potential cause and hardware solution.
    Same problem: Watching a video on YouTube after a fresh boot up would cause the System and System Interrupt processes to collectively use approx 20-25% of the CPU.  Fan would go crazy with Chrome and Firefox and to a lesser extent with Edge.  I was able to replicate the problem.
    My setup: SP3 connected to:
    1. VGA monitor, and
    2. USB hub (with own power supply) with two devices:
      • Keyboard/mouse receiver
      • USB speakers (with own power supply)
    Solution:
    I swapped out my USB 3.0 hub with a USB 2.0 hub. After doing that, the problem has not occurred.   As others have noted, the issue does seem related to the Realtek audio driver.  I'm not a technical person but my guess is that there is a problem with how Windows 10 is outputting audio and switching from the Realtek audio driver to the driver for my USB speakers.  Not sure what role the USB hub plays in all this.
    Additional info:
    USB speakers are Bose Companion 5
    When they were plugged into a USB 3.0 hub, they would occasionally emit a buzzing noise during startup.  They no longer do that with the USB 2.0 hub.
