2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-11-03T08:47:54+00:00
    Add another person with the bug to the pile. After I do something involving audio, like watch  YouTube video in IE11, the System process invariably spikes to 14-20% CPU and causes the fan to kick on non-stop. This also happens if I hibernate or sleep the device and wake it up again.
    As soon as I disabled "Realtek High Definition Audio" in Device manager, or even "DING" the audio by clicking the system tray voume icon, my CPU usage went to near 0%. As soon as sound stops playing, back to 14% - 15% CPU usage.
    Most recently, the CPU spiked to 40% usage and I was unable to use the device at all. SFC is scanned, DSIM is checkhealth clean, CHKDSK is clean, drivers and firmware are straight from MS Windows Update. SP3/8/256.
    To the guys at MS, this is a bit silly by all admissions -- the culprit is clearly the "Realtek High Definition Audio" driver or something in the Windows Audio subsystem. This bug has been around since 2014, from Windows 8, through Windows 10.
    It is absolutely bonkers this hasn't been fixed by now. Apple would be hanging engineers from the rafters until it was fixed. (I know this because a friend working there didn't get to come home for about a month during one such situation.) Please, use your weight as the largest Software and Services company in the world to make Realtek fix this!
    2015-10-31T12:55:50+00:00
    Hi, I am using a Surface 3 LTE and I have the same Problem.  I recognized that a Device "i2C HID" is listed twice and in the device manager one has a "!". I had the Problem two weeks ago, than it suddenly was not there anymore. This device in the device manager was listed only once.
    Now the problem is evident again CPU load (due to "system-interrupts") is again 25% or higher and the device mentioned above is listed twice, with "!" again.
    I'm in contact with the surface support. They are really very helpful but didn't find the problem either.
