2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-10-20T10:00:36+00:00
    I'm the OP of this thread. And boy does Microsoft need to address this, now the newer Windows 10 Surface Pro 3's that are shipped out still have this issue. Is it wrong to assume that even the Surface 4 Pro will have this issue?
    MS come on, get your act together and stop ignoring this issue. You know about, you replied to the thread and then put it in the too hard basket?
    I expect this will be deleted at some point to try and cover up the issue like most large tech companies would.
    2015-10-19T10:43:02+00:00
    Good morning,
    Just to give some support to the thread, as I bought a Surface 3 last week that comes from factory with Windows 10. This is hardware and software 100% controlled by Microsoft, and I get 30% CPU usage due to drivers? Come on!!! No excuse!
    I will try the microphone work around, but I use Skype which is a bummer :(
    I don't know why, but if I restart the problem is there still. So, dunno what I am doing wrong.
    My guess is Microsoft Id not aware of this yet. We need to give them visibility. So I would encourage **all** people to vote for this issue (all in the same one) in Windows Feedback app, so that it shows in their analytics. I guess they don't monitor these support forums very well. But they are very on top of the windows feedback app.
    Very disappointed like you guys with this. Hope it will be solved ASAP.
    All the best,
    JC
