2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-09-25T15:21:38+00:00
    Wow I think that one of the last windows updates finally fixed the problem for me!
    Now with a microSD in the slot, if I shutdown and then I turn on the surface (without reboot), the CPU usage is at normal levels!
    2015-09-25T08:14:25+00:00
    I had the issue only after waking / starting when docked. Undocked there is no issue.
    I tested it with nothing connected to the docking station - except power... issue persists.
    I tested with another docking station - no issue!
    I got it replaced - bingo!
