2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-05-15T07:27:48+00:00
    The problem still hasn'r re-surfaced. Can you guys please try and install the newest Realtek audio driver (v2.77) and post your feedback? Thanks.
    2015-05-14T01:19:08+00:00
    2.77 Realtek driver looks so far so good.But it's been only overnight so I'll give it some more time
