2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-05-13T20:16:10+00:00
    I install the latest driver. Test it...I saw the same behavior but when I disable the realtek driver the issue got fix for about in 20 seconds it came back again with while the realtek driver still disabled....I guess this time was not related to realtek but with other hardware component. I don't know what it is....usually if this happens I have to just restart the surface again to fix. Pretty annoying.
    This happens regardless if the surface is in the docking station or as stand alone tablet.
    Also happens on battery or with power source.
    The only way to check which other driver gives problems is to go ahead and when the issue appears start disabling component by component on device manager and give some time to see if that fix it...if not re-enable again and continue doing this until you find the trouble maker. That's how I discover the problem with the RealTek driver.
    Its a process that takes some time.
    2015-05-13T19:01:45+00:00
    I just run Sound Recorder from Accessories and keep it permanently open and idle.  Works for me.  I avoid shutdowns and use hibernate instead to dont bother with recorder restarts.
    I agree:  SHAME ON MICROSOFT FOR NEGLECTING THIS ISSUE.
