2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-05-20T06:12:10+00:00
    As of yesterday back to square one :(
    2015-05-15T11:14:24+00:00
    The problem still hasn'r re-surfaced. Can you guys please try and install the newest Realtek audio driver (v2.77) and post your feedback? Thanks.
    Sorry, still the same Problem for me! The driver changed noting on my end.
