2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-05-02T16:50:02+00:00
    Just two items in the one year long Microsoft Surface Pro 3 CPU bug which can make this tablet unusable without the power supply:
    The only reliable way I have found to deal with this system software bug in the interim is to play music using the music app, put it an infinite loop, and mute the sound.
    To truly fix the problem, the press is going to need to be involved to raise the issue higher up the chain and raise the possibility that sales will be jeopardized.
    The New York Times, and Wall Street Journal both have computing/technology sections and might be interested in this issue as an investigative journalism piece showing how a large tech company that's literally deaf to the problems experienced by their users.
    Media, if a search engine has made this problem visible to you, please help!  Users, please forward this issue to your favorite investigative journalists!
    2015-04-20T08:40:55+00:00
    I have the same issue too. SYSTEM is around the 25-30 of high CPU. With Process Explorer we couldn't find anything related. We tried to reinstall the High Definition Audio Driver, but without hope.
