2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-05-03T08:15:36+00:00
    To be honest, I also struggle with this problem. Firstly I disabled Realtek Audio, which helped for some time, but then it starts again, caused by some USB device. Since then MIcrosoft issued two firmware updates and the problem now stops. I still have Realtek Audio disabled, because I don't need it and I won't test it if it works, and none of the latest firmware updates mentioned this issue explicitly as targeted bug fix, but there was some progress.
    2015-05-02T18:00:44+00:00
    Just two items in the one year long Microsoft Surface Pro 3 CPU bug which can make this tablet unusable without the power supply:
    The only reliable way I have found to deal with this system software bug in the interim is to play music using the music app, put it an infinite loop, and mute the sound.
    To truly fix the problem, the press is going to need to be involved to raise the issue higher up the chain and raise the possibility that sales will be jeopardized.
    The New York Times, and Wall Street Journal both have computing/technology sections and might be interested in this issue as an investigative journalism piece showing how a large tech company that's literally deaf to the problems experienced by their users.
    Media, if a search engine has made this problem visible to you, please help!  Users, please forward this issue to your favorite investigative journalists!
    The trouble is these sites and journalists are corrupted and get sent free review SP3's. And if they were to write about this issue, MS would never give them another product to review ever again. Such is the way of the corrupted tech review sites and how their bias reviews work.
    They can only write about little small issues, like the touchpad is small, nothing like this year long issue that MS turns a blind eye to. Apparently this issue is present in the new 10.6" Surface 3, which although it has an Atom CPU, uses the same Realtek sound card, crappy Marvell wireless ac card and this exact same issue. But MS don't care. I expected this thread to have been deleted by now. I'm sure it wont be up for much longer.
    I'm the OP that started this thread btw....
