2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-04-17T07:32:16+00:00
    I have the same Problem. The Surface Pro 3 is not useable for me, while using hibernation. Only with connected standby it works...
    Please Microsoft fix this!
    2015-04-14T14:16:22+00:00
    So, I have the same problem with my Surface Pro 3, I7, 256GB.
    Processe System Interrupts are using about 8-9% of processor usage.
    In idle situation, my machine is using around 25% total CPU ...... it's insane.
    If I disable the Realtek audio driver it seem to solve my problem.
    My CPU returns to 2-4% of total CPU usage.
    So, cleary it's related with Realtek Audio driver,
    Microsoft please solve this probelm.
    Thanks!
