2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-07-30T21:28:01+00:00
    I have the commonly known problem where System Idle and System Interrupt processes will use up to 30% of CPU load for no apparent reason.
    I've read that this commonly happens after waking up from sleep, but in my case it's the opposite: this only happens after I shutdown. If I restart, it eliminates the problem. If I sleep after a shutdown, the issue persists. If I sleep after a restart, this problem remains gone.
    I do not have an SD card inserted.
    Problem with sleeping, as opposed to simply shutting down, however, is that it randomly wakes up for no obvious reason. This is IMMENSELY annoying when I'm trying to rest, and the lights pop up for no reason.
    So what do I have to do? When I'm about to go to sleep, I shutdown the computer. When I wake up and turn the computer on, the idle interrupt problem kicks back in, so I have to restart the system immediately after login. Excuse my language, but this is f*cking ridiculous, especially considering how much money I paid for this device.
    I already have all the updates installed up to July 30th but these issues still persists. This problem has been documented since the Surface Pro 2, which begs the question why are you guys releasing everything so quickly if you can't even fix the basics? Everything about how the Surface Pro 3 runs feels like it's still being beta tested.
    2014-07-30T11:07:05+00:00
    Its defiantly linked to the MircoSD card slot if it boots with a MicroSD card inserted this issue will appear.
