2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-07-31T21:24:03+00:00
    Yes its still an issue and its such a pain. My system fan is always on and its hot. 33% more of my systems power is taking up by this bug. I think I might have to just return it or sell it.
    Cold boots are an issue too and without the sd card inserted I still have issues! Please MS can you get onto this issue. Its there all right.
    My system is a 256GB i5 8GB model.
    2014-07-31T20:03:08+00:00
    Just wanted to chime in that I have this issue as well. However, I've never used a microSD card at all, so I don't think it's related to just the SD card.
    In my case, doing a shutdown, and turning it back on will get the CPU usage skyrocketing.
    However, restarting always fixes the problem. But it's annoying to have to turn on a computer, then restart it immediatley again just to get it working properly.
    Interestingly, I turned off fast startup in the power options hoping that it treats shutdown as a clean reboot instead of the hybrid shutdown, but even after that the problem persists. It's ONLY for shutdown. Not for restart.
    Which makes absolutely no sense. What the **** is the point of turning off fast startup if it doesn't behave like an actual clean reboot?
