2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-07-28T22:00:08+00:00
    Hi Chris,
    Thank you for your response and answers to my questions. So the issue appears after the device wakes up from sleep and a complete shut down.
    • I see that you have the Type Cover and a microSD card. Have you tried turning the device on (from a cold boot, a restart, or sleep) to see if it makes any difference?
    • That's interesting how you found that the sound might have something to do with the CPU load. Was the sound turned off when you found out about this problem? What happens if you turn the volume on/up, let the device to sleep/shut down, then turn it back on? Even if the sound was off, after waking the device and turn the sound on, does the problem disappear?
    Let me know!
    I have found that without the SD attached I have less chance of this happening. Cold boots it can still do this as I shutdown and then booted from a cold start and struck the issue.
    I found that when I watched the CPU use % in task manager when playing Audio the system and system interrupts would stop hogging the CPU and things would return to normal. Once I stopped playing the MP3. It would return.
    Volume up and down. Mute make no difference.
    Again it seems to be connected to the Realtek audio driver or MircoSD card slot?
    2014-07-28T20:56:31+00:00
    Hi Chris,
    Let me know!
