2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-07-24T15:44:44+00:00
    Hi Chris,
    Thank you very much for reaching out to the Surface Community! I appreciate you taking the time to contact us to express your concerns. According to the picture, it does seem that System interrupts are taking up a lot of space - I will try my best to resolve the issue for you.
    • Do you have any accessories attached to the device, namely a Cover or a microSD card? Does it make a difference if they are all taken off?
    • I understand that the problems mostly occurs when waking from sleep. Is there a noticeable difference between waking up from sleep and turning on from a complete shut down?
    Let me know!
    Yes I have a Type cover for the SP3 attached and a sandisk 64gb microsd card.
    I normally find after turning on from a complete shutdown. I can replicate the issue putting the system into sleep or hibernate.
    I also notice that if I play sound, the CPU load on system and system interrupts will return to normal. Which makes me think its related to the sound?
    2014-07-24T15:15:47+00:00
    Hi Chris,
    Let me know!
