2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-02-20T08:14:43+00:00
    Sorry for the delay in my reply I have been out of the office.
    To cut a long story short the problem has gone away.  I didn't make any changes to trigger the fix, it just started behaving itself, so I've been using the SP3 for a good number of days now without any re-occurrence.
    It has developed a new issue when booting, it sticks on Surface bios screen if I have monitors connected to the dock and the displayport on the device simultaneously but I can live with that as I normally boot it before docking anyway. Unfortunately my monitors don't support displayport chaining, one is displayport one is DVI.
    Thanks for the initial response!
    Cheers
    Alex
    2015-02-18T19:09:16+00:00
    Disabling audio worked around the problem for me, too.  However, if you have time to spare and can test just disabling enhancements, I would be curious to know how that works for you.
    Right click system tray speaker -> Playback devices -> Speakers, Realtek High Definition Audio -> Enhancements -> uncheck Enable
    I still get sound from my SP3's speakers, Bose, and headset ... but without whatever "Enhancements" provides and without System and System interrupts racing.  I haven't researched what I'm missing without "Enhancements" -- been busy -- but will.  I may try new Realtek drivers from Realtek, too.
    Disabling the sound card will definitely fix the "systems" "systems interrupt" issue with the surface however disabling the enhancements did not fix the issue at least for me. If you disable the enhancements when you play music or video sound levels would be very low. That happens when the surface is not on the docking station. This is using the internal speakers. You have to enable enhancements to make it sound right. Its definitely an issue with the realtek driver quality.
