2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-02-18T17:26:07+00:00
    Disabling audio worked around the problem for me, too.  However, if you have time to spare and can test just disabling enhancements, I would be curious to know how that works for you.
    Right click system tray speaker -> Playback devices -> Speakers, Realtek High Definition Audio -> Enhancements -> uncheck Enable
    I still get sound from my SP3's speakers, Bose, and headset ... but without whatever "Enhancements" provides and without System and System interrupts racing.  I haven't researched what I'm missing without "Enhancements" -- been busy -- but will.  I may try new Realtek drivers from Realtek, too.
    2015-02-18T17:21:11+00:00
    Here's the fix:
    Disable Sound Card!
    in Control Panel->Device Manager->Sound, video,game controller->realtek audio->disable it
    Yes, this is not perfect any way, it mutes all the sound on your surface. But it saves battery a lot.
    Before Microsoft fix it, we have to carry on.
    Microsoft, Listen, it's definitely related to Sound Card/Driver!
    Kudos ... this information helped.  What I mean by that is: I used this information for further Binging and discovered that you may not need to disable audio but maybe just disable the audio enhancements:
    I still get sound from my SP3's speakers, Bose, and headset without System and System interrupts racing ... but without whatever "Enhancements" provides.  I haven't researched that yet -- been busy.  I may try new Realtek drivers from Realtek, too.
    If you have time to spare and can test just unchecking Enable, I would be curious to know how that works for you.
