2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-02-17T05:33:55+00:00
    There doesn't seem to be much a troubleshooting section here for major battery drain issues, so perhaps it would be helpful if some of us could post our experiences.  I've had my SP3 for a few weeks, and I love everything but the battery.  But tonight took the cake.  I closed the type cover, put it in my bag, and went to my part-time (2 hours on Monday nights) job.  The battery was at 100% when I put it in my bag.  I drove there at 5:30, got a few things set up, and was using it off and on by 6.   At 6:30, the battery was down in the high 80s (a little under an hour, screen at about 30%).   I left it in sleep mode for an hour, and then woke it briefly for use with my last private student;   After his lesson was over at 8 p.m., I noticed it was already down to 73%.
    I came home, took it out of my bag (still warm), and sat it on a table while I did some cleaning.  I sat down at 10:20 p.m..  It was at 20%.  Over 50 percent battery loss in 2 hours and 20 minutes supposedly in sleep mode (although I suspect that wasn't working correctly -- but even if it wasn't, with no programs open and the screen at 30%, it should not lose that much battery, I wouldn't think.
    I have no idea what's causing it.   I know sometimes the type cover does not do its job with putting/keeping it in sleep mode.   So I've been putting it into sleep mode manually, and disabled the type cover's ability to wake it from sleep (although sometimes it still does).
    The only things running in the background are ccleaner, google drive sync, dropbox sync, iTunes helper, the typical iCloud stuff, and OneNote clipper.
    There's nothing plugged into the usb port, but I do leave bluetooth on, as I often want to quickly use the pen.
    Any one of these things known for sporadically draining a ton of battery or messing up sleep mode?
    TIA
    Rob
    2015-02-13T20:05:37+00:00
    I have been VERY happy with my Surface Pro 3 until recently.  I noticed it a couple of days ago but today it was markedly HOT when I went to use it this afternoon.  I wonder if this malfunction has been corrected in updated versions.  When it "goes to sleep" the backlight never goes off so i'm wondering if this has anything to do with this issue.  Today is was so hot i could not touch the screen.  it did not give a temperature warning was just very hot to the touch.
    Please let me know if i should return for a refund or if there is a fix for this issue.
    Thanks for your attention.
