2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-03-10T18:39:43+00:00
    So, I'm experiencing this too, sadly.  A few observations from my case:
    1. Problem manifests right away when doing a cold boot while docked
    2. A restart while docked seems to fix the issue; at least it doesn't appear immediately
    3. Interestingly, when manifesting, the excessive System and System Interrupts activity dies down completely after opening the Sound control panel applet (right-click on speaker icon in task tray, select Playback devices). But when the Sound applet is closed again, the problem resumes almost immediately.  This does suggest that the problem is somehow audio driver related.
    4. Disabling the various audio devices from this interface has no effect on the problem (while docked I have the built in speakers and headphones, plus Dell display audio, and Benchmark DAC USB audio)
    I'll update this post if I notice any further behaviors.
    Microsoft, where are you?
    2015-03-03T12:43:05+00:00
    Thanks for the help. After removing MicrosSD Card andmost recently USB Controlers, the battery returns to it's normal consuption. After reinstall the USB controles I had no problem (yet).
