2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-01-24T00:09:09+00:00
    OK- now putting it in airplane mode does not even work.  It was supposed to be asleep and I had airplane mode on.  It was in my bag for an hour.  It was warm in the upper right corner of the device and had lost 6% of battery.  Uggghhhh.  I give up.  I have the i5 256GB 8GB Pro3.  Anyone else have ideas???!!???
    2015-01-23T21:59:29+00:00
    I guess I celebrated too soon.  The above worked for 2 days, then the battery drain started again.  The dreaded USB xHCI Compliant Host Controller came back to be active 100% of the time in sleep mode (as found on the sleep study).  I decided to just turn Bluetooth off completely.  That actually worked for about a day, but now I get the drain again.  The dreaded USB xHCI thing is now active 73% of the time in sleep mode.  Whenever the USB xHCI thing is active in sleep mode, it prevents the device from sleeping correctly.  That is for sure, as I have completed many sleep studies, and when it is present, the Low Power State is 0% and the battery drains about 4-5% per hour for four hours then it "hibernates".  If the USB xHCI is not active during sleep, the Low Power State is about 99% and the battery drains less than 1% per hour for 4 hours (about 3% total) and then it "hibernates".   I guess I will go back to putting in airplane mode before sleep.  If this measure stops working, I will post again.  I am just about ready to give up on this device.  This should not drain by 19-20% when not in use for 4 or more hours.  And I should not have to put it in airplane mode or completely shut down after each use.  That defeats the purpose of the sleep mode and InstantGo.  I realize that connected standby is just that, it remains connected- but this device has worked great at times (especially when I first bought it) and did not lose battery power like now.
    If somebody else has a solution, please let us know.
