2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-01-24T13:45:47+00:00
    i have not  movedfurther than you.
    I found out, that keyboard is iluminated when cover is closed. As well screen goes on some times without any reason, any activity.
    Microsoft should adress this topic and give us some solution.
    I hope they will make a solution as I do not want HW change as I see in previous cases it did not work.
    2015-01-24T08:09:12+00:00
    Make sure that you have at least 20 GB of free space on the Windows partition... that is a MUST.
    Michael
